I'm trying to read the data from an Oracle Locator database into FME. When reading data through both the Oracle Spatial Object reader and the Oracle Non-Spatial reader everything goes fine.
However, with the Oracle Spatial Relational reader, I get the following errors when trying to get the table list (see image 1):
The log file says the following (see image 2)
Am I getting this error because I "only" have the Oracle Locator database, and not a full Oracle Spatial database? Or is the error due to missing parameter settings? To be clear, I'm using the same database connection.
