parallel processing level in FME Base edition
  • February 23, 2014
  • 6 views
jaro
as mentioned earlier, I am currently working with FME Base edition, which has certain limitations. I want to ask if somebody happen to know if parallel processing is available in FME Base edition. In the dialog, the parallel processing level may be set in range from "No parallelism" to "Extreme". However, for options other than "No parallelism" I sometimes get an error message saying  that TransporterFactory is not licensed.
Does it have something to do with Base edition or am i doing wrong something else?
The available documentation doesn't say anything about parellelism in FME Base.
Thanks,
Jaro
Best answer by david_r
the message you're citing leads me to believe this feature isn't available in the base edition. Perhaps a mail to Safe support to verify is in order.
Having said that, I never use this feature myself. After having experimented a fair bit with different settings under FME 2013, I have yet to see any performance gains worth mentioning.
Your mileage may vary, but that has been my experience with all workspaces tested.
David
  • February 24, 2014
David
