permute a list, output to csv
  • November 27, 2014
  • 9 replies
  • 104 views
I have a list of features, and I want to output a permutation of all combinations of two and two list members to a csv file.
Example:
Feature 1
List{0} = 11
List{1} = 22
List{3} = 33
Feature 2
List{0} = 44
List{1} = 55
....more features
Should produce this csv-file:
11, 22
11, 33
22, 11
22, 33
33, 11
33, 22
44, 55    Remark: This is feature 2
55, 44
The lists seem to be fine, I can use AttributeExposer and output single items. So my challenge is to output the combinations while not knowing before rruntime how many list members there are (will most often be 2, and generally less than 4).
I have been experimenting with listExploder to give me one line per list member, but it leaves me with the combination problem. I'm new to FME, so a suggestion of appropriate transformers would be appreciated. Thank,s.
Regards Erik
Best answer by takashi
Hi Eric,
I think you are on the right track - the ListExploder.
The point would be how to do "CROSS JOIN" after the exploding.
The FeatureMerger (Process Dupliacte Suppliers: Yes, Duplicate Supplier List Name: <list name>) + ListExploder performs the processing like "CROSS JOIN".
If you are familiar with SQL, the InlineQuerier can also be used effectively.
Takashi
  • November 28, 2014
Hi Eric,
Takashi
  • November 28, 2014
In the first approach, the ListExploder_2 is not essential.
You can remove it, and connect the AttributeRenamer_2 to the first ListExploder.
  • November 28, 2014
Update.
  • November 28, 2014
Scripting could be simpler and faster. All the transformers can be replaced with a PythonCaller (Attributes to Expose: Field1, Field2).
# Script Example for the PythonCaller
import fmeobjects
class FeatureProcessor(object):
    def input(self, feature):
        L = feature.getAttribute('List{}')
        if L:
            for v1, v2 in [(v1, v2) for v1 in L for v2 in L if v1 != v2]:
                newFeature = fmeobjects.FMEFeature()
                # If you need to retain the List{} and other attributes,
                # replace the line above with this.
                # newFeature = feature.cloneAttributes()
                newFeature.setAttribute('Field1', v1)
                newFeature.setAttribute('Field2', v2)
                self.pyoutput(newFeature)
Several ways. You can have your choice ;)
  • November 28, 2014
Hi Takashi,
Many thanks. The InlineQuerier did the trick perfectly for now. Maybe I'll also check out the PythonCaller at a later stage, so thanks for that example as well.
Erik
  • November 29, 2014
I've overlooked a case where duplicate elements occur in a List.
e.g. List{} = [11, 22, 22]
In such a case, the workspaces discard combinations that consist of same values.
11, 22
11, 22
22, 11
22, 11
Could there be duplicate elements in a List?
If you need to create {22, 22} in such a case, you will have to modify them.
11, 22
11, 22
22, 11
22. 22
22, 11
22, 22
SQL:
1) Set the "Element Index Attribute" of the ListIndexcer. e.g. "_element_index"
2) In the InlineQuerier, add column to the Source Table.
Name: _element_index, Type: integer
3) Modify the SQL statement:
select a.List as Field1, b.List as Field2
from Source as a cross join Source as b
where a._count = b._count and a._element_index <> b._element_index
Python:
Modify the script.
import fmeobjects
        if L:
            for v1, v2 in [(v1, v2) for i, v1 in enumerate(L) for j, v2 in enumerate(L) if i != j]:
  • December 1, 2014
For this specific list, there should be no duplicates in the list (and if it were, I'd be happy to get rid of them). For more general use, you point out an important thing to consider, so thanks for the update.
  • August 12, 2015
Hi! I am having a simular problem, but cannt get the feature merger method to work and I am not an SQL person...
I have a table with cell IDs, that all relate to a path. some cells relate to start and some relate to end. There can be duplicate cell IDs relating to different paths. I need to find all possible combinations of start to end cells by path which I will later use to route with. Here is an example of my table structure:
Cell_ID, Type, Path
1 End 3
2 End 3
3 End 3
4 End 3
5 Start 3
6 Start 3
7 Start 3
8 Start 3
9 Start 3
10 End 5
11 End 5
12 End 5
13 End 5
14 Start 5
15 Start 5
16 Start 5
1 Start 5
2 Start 5
3 Start 5
I have tried seperating start and end then feature merging on path with duplicate suppliers. This gives me the correct number of records once the list has been exploaded (e.g. is there are 10 start and 10 end in a path I should have 100 records). But they are all duplicates.
I have also tried the counter idea from above and I get the same amount of records out as I put in. Instead of finding all combinations it is just a 1-1 join.
Any ideas?
  • August 12, 2015
I think you are on the right track, but maybe the setting of the "Accumulation Mode" parameter in the ListExploder should be modified.
e.g.
Hope this helps.
Takashi
