Cancel running / queued jobs
vki
Forum|alt.badge.img+7
Hello
I'm new to FME Server, so this is probably an easy question:
Is it possible to cancel a running job or to kill jobs in the queue (in the FME_Server User Interface)?.
I searched for the answer in the forum, but I didn't find one (that I understood...)
Thanks, Vera
Best answer by david_r
Yes, that is possible. Simply select the job by checking the box on the left of the chosen job entry (queued or running), then select the Cancel button on the top right.
You can find more information in the documentation:
https://docs.safe.com/fme/html/FME_Server_Documentation/WebUI/Removing_Jobs.htm
vki
  • May 27, 2019
oh, silly me...
Thanks!
