ArcPy "import" statement tries to perform import action?
  • December 14, 2016
  • 5 replies
  • 12 views
In my startup script I use an "import ArcPy" in order to create a new version of my ArcSDE database. I changed the Python interpreter to C:\Windows\SysWOW64\python27.dll.
My code (some "private parts" disguised with <XXXXXX>
import sys
import datetime
import arcpy
import fme
inWorkspace = r'<XXXXXX>BUDATA/ArcSDE Connecties/GABUAPP_AREAALDATA.sde'parentVersion = 'sde.DEFAULT'
versionName =  'GISIBsync_' + datetime.datetime.now().strftime('%Y%m%d_%H%M%S')
arcpy.CreateVersion_management(inWorkspace,parentVersion,versionName,"PUBLIC")
To my surprise during runtime it seems as if the startup script is trying to create an Autodesk 3Ds reader (in bold in the output beneath), which is strange since my FME-workspace only contains Oracle Spatial and ArcSDE readers. It also seems that this reader is trying to read the ArcGIS toolboxes (!).
Even stranger: after this unsuccesful creation of a reader, the startup script continues, and finally creates the ArcSDE database version.
Starting translation...
2016-12-14 09:05:02|   0.8|  0.8|INFORM|FME 2015.0 (20150217 - Build 15253 - WIN32)
2016-12-14 09:05:02|   0.8|  0.0|INFORM|FME_HOME is 'C:\Program Files (x86)\FME\'
2016-12-14 09:05:02|   0.8|  0.0|INFORM|FME Desktop Oracle Edition (floating)
2016-12-14 09:05:02|   0.8|  0.0|INFORM|Permanent License.
2016-12-14 09:05:02|   0.8|  0.0|INFORM|Machine host name is: <XXXXXXX>
2016-12-14 09:05:02|   0.8|  0.0|INFORM|START - ProcessID: 1136, peak process memory usage: 53012 kB, current process memory usage: 53012 kB
2016-12-14 09:05:02|   0.8|  0.0|INFORM|FME Configuration: Command line arguments are `C:\Program Files (x86)\FME\fme.exe' `D:/git_repo/Etl/Geodatabase_writer\wb-xlate-1481702696704_1512' `LOG_STANDARDOUT' `YES' `LogCountServerName' `{c70fed7a-9180-42a0-a51c-7f03e505c4b8}'
2016-12-14 09:05:03|   1.0|  0.2|INFORM|Using user-specified Python interpreter from C:\Windows\SysWOW64\python27.dll
2016-12-14 09:05:03|   1.0|  0.0|INFORM|Python version 2.7 successfully loaded
2016-12-14 09:05:03|   1.0|  0.0|INFORM|FME_BEGIN_PYTHON: evaluating python script from string...
2016-12-14 09:05:12|   8.8|  7.8|INFORM|FME Extension for ArcGIS (9) (20140217 - Build 14241 - WIN32)
2016-12-14 09:05:12|   8.8|  0.0|INFORM|FME 2015.0 (Build 15253)
2016-12-14 09:05:25|  20.2| 11.4|INFORM|Creating reader for format: Autodesk 3ds
2016-12-14 09:05:25|  20.2|  0.0|INFORM|Trying to find a DYNAMIC plugin for reader named `3DS'
2016-12-14 09:05:25|  20.3|  0.0|INFORM|Loaded module '3DS' from file 'C:\Program Files (x86)\FME\plugins/3ds/3ds.dll'
2016-12-14 09:05:25|  20.3|  0.0|INFORM|FME API version of module '3DS' matches current internal version (3.7 20141021)
2016-12-14 09:05:25|  20.3|  0.0|INFORM|Creating reader for format: Autodesk 3ds
2016-12-14 09:05:25|  20.3|  0.0|INFORM|Trying to find a DYNAMIC plugin for reader named `3DS'
2016-12-14 09:05:25|  20.3|  0.0|INFORM|3DS Reader: Reading in Variable FeatureType mode
2016-12-14 09:05:25|  20.3|  0.0|INFORM|3DS Reader: Opening dataset: 'C:/Program Files (x86)/ArcGIS/ArcGISDataReviewer/Desktop10.2/ArcToolbox/Toolboxes/Data Reviewer Tools.tbx'
2016-12-14 09:05:25|  20.3|  0.0|ERROR |3DS Reader: Failed to load file: 'C:/Program Files (x86)/ArcGIS/ArcGISDataReviewer/Desktop10.2/ArcToolbox/Toolboxes/Data Reviewer Tools.tbx'
2016-12-14 09:05:25|  20.3|  0.0|ERROR |3DS Reader: Error opening the dataset: 'C:/Program Files (x86)/ArcGIS/ArcGISDataReviewer/Desktop10.2/ArcToolbox/Toolboxes/Data Reviewer Tools.tbx'
2016-12-14 09:05:25|  20.3|  0.0|INFORM|3DS Reader: Closing reader
2016-12-14 09:05:25|  20.3|  0.0|WARN  |UniversalReader -- readSchema resulted in 0 schema features being returned
2016-12-14 09:05:25|  20.3|  0.0|WARN  |Reader Parameter(0) = >C:\Program Files (x86)\ArcGIS\ArcGISDataReviewer\Desktop10.2\ArcToolbox\Toolboxes\Data Reviewer Tools.tbx<
2016-12-14 09:05:25|  20.3|  0.0|WARN  |Reader Directive(0) = >UNIQUE_ID_ATTRIBUTE<
2016-12-14 09:05:25|  20.3|  0.0|WARN  |Reader Directive(1) = >FME_FEATURE_ID<
2016-12-14 09:05:25|  20.3|  0.0|WARN  |Reader Directive(2) = >PERSISTENT_CACHE<
  • December 14, 2016
First of all, you can drop the "import fme" statement and see if that makes a difference.
Also, try temporarily removing the startup script and compare the logs, does FME still try to create the Autodesk reader?
  • December 14, 2016
Dropping the "import fme" doesn't make a difference.
When removing the startup script completely FME doesn't create the Autdesk 3Ds Reader. Also, when having a startup script without import ArcPy the Autodesk Reader isn't created.
One thing to note is that our ArcGIS (10.2.2) setup includes the Data Interoperability extension.
Perhaps this lead to a sort of "circular reference"?
(unfortunately I can't remove the Data Interop extension myself to check it out, the entire setup of both FME and ArcGIS have been scripted)
  • December 14, 2016
The Data Interop might possibly explain it, but that sounds like a question for Safe support.
Is it a show-stopper for your workspace?
  • December 14, 2016
Not a show-stopper, as the script continues and creates the new version in ArcSDE.
But a bit inconvenient, since I'd rather have my scripts & workspace error-free
  • December 14, 2016
I can symphatize. Consider opening a support ticket with Safe: https://support.safe.com/knowledgeSubmitCase?
