Tiler for parallel processing failing in FME Server
Hello everyone,
I am trying to utilize tiler for parallel processing in FME Server environment. Workbench that has tiler transformers and parallel processing enabled, runs fine in FME Desktop environment. However, if i try to run the same workbench via FME Server, it throws the following error:
Tiler_2_PointCloudTiler(PointCloudTilingFactory): The keyword TILE_ROW_ATTRIBUTE has incorrect arguments. The clause must look like: TILE_ROW_ATTRIBUTE <attribute name>, where <attribute name> is the name of a new attribute that will be added to output features
Any help with this issue would be much appreciated.
Thanks!
Boris
Best answer by boriskirov
I have just resolved the issue - Originally, I have published the workspace from FME Desktop 2018 which is in Beta status. After republishing it from the latest stable release (2017.1), all seems to be working fine.
Thanks!
Cheers,
B.
Hi @boriskirov
What version of FME Desktop and FME Server are you using?
Are you able to upload the workspace you have so we can take a look and test it?
  • February 1, 2018
Thanks!
Cheers,
B.
  • February 1, 2018
jlutherthomas wrote:
Hi @boriskirov
Thanks!
Cheers,
B.
fmelizard
Forum|alt.badge.img+17
  • February 1, 2018
boriskirov wrote:
Thanks!
Cheers,
B.
Hi @boriskirov,
Thanks for letting us know.
