Re-combining polygons as rings in a polygon
  • November 26, 2012
  • 20 views
I have input polygons that consist of multiple disconnected rings (as islands) and I am generalising them and removing islands of less than a certain area. I am using Generalizer, DonutHoleExtractor, SpatialFilter and DonutBuilder to do this and it works well, but the resulting layers are now individual polygons. I want to combine the polygons as rings in single polygons based on a unique ID. Can someone recommend a method of doing this please?
gisbradokla
Forum|alt.badge.img+16
  • November 26, 2012
I think you want the dissolver and possibly the featuremerger.
fmelizard
Forum|alt.badge.img+17
  • November 26, 2012
Have a look at the aggregator, you can combine all the polygons into one aggegate.
Itay
