A customer has FME Cloud. But now they need to write to GDB (ArcObjects) for raster writing.How should we add ESRI support?
ESRI support on FME Cloud?
Best answer by gerhardatsafe
Currently on FME Cloud only the Esri Geodatabase (File Geodatabase Open API) is supported. The reason for this is that the Esri Geodatabase (File Geodb) format would require an installation of ESRI software on the same machine which is not supported for several reasons (OS is Linux & there is no access to the machine itself). Even SDE legacy (which will be deprecated by ESRI soon) can not be supported as we can not install the library on the instance.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
