Extract X,Y from midpoint of line
  • November 26, 2013
  • 155 views
I'm not sure how to extract the X,Y attribute from the CenterPointReplacer?
I have my line feature feeding into the CenterPointReplacer transformer, this creates my Midpoint "Point" perfectly, but when i add this Point into my workspace (GeoMedia) the X,Y attribute are not to be seen?
Thoughts
Best answer by takashi
Hi, you can use the CoordinateExtractor transformer to do that.
  • November 26, 2013
  • December 2, 2013
Takashi, I have successfully extracted the X,Y of the midpoint of a line by using this workflow: CenterPointReplacer --> CoordinateExtracter --> Attribute Creator (creates the X,Y Attribute).
The Problem now is I have a point file where I actually need the original reader feature (Polyline) with the X,Y Coordinate attached to it ?
