Parsing JSON list of ObjectIds from rest service
I need to download some data that's only available through a Map Service on a public ArcGIS server. I was thinking of downloading the data 1000 features at a time using JSON, but in order to do that I need to get the list of ObjectIds. The list of ObjectIds gets returned in a query request and the response looks similar to this:
{ "objectIdFieldName": "OBJECTID", "objectIds": [ 1, 2, 3 ] }
I could parse this using Python, but I would like to be able to do it in FME 2014. When I use the JSON reader, each objectId gets read as a separate attribute and FME ends up hanging because it's trying to read tens of thousands of attributes! Is there a parameter setting or a better reader or transformer that would help?
bruceharold
Forum|alt.badge.img+17
  • August 17, 2016
Do you mean a feature service? There is a reader for that, it will handle the pagination for you.
  • August 17, 2016
@bruceharold Unfortunately I'm using FME 2014 and there isn't a reader for feature services on ArcGIS Server.
itay
  • August 17, 2016
How about reading it with the text reader and parsing it with a json transformer?
  • August 18, 2016
Unless you have some very hard constraints, I suspect it will be much less labor-intensive to upgrade FME than to try and re-create the reader. Judging by the number of bugs (I'm using the term lightly) in the early versions of the FME reader I can only assume that accessing the feature service isn't trivial.
todd_davis
Forum|alt.badge.img+22
  • August 18, 2016
Yes, read as txt and pass to JsonFlattener...expose attribute: objectIds{}. Next put into a listexploder...
If you are going down this path, realise that you won't be able to pass heaps of objectids in a querystring (if using GET request) as the default in IIS allows for 2048 bytes....I have some details around the breaking that down into manageable chucks.
I have a workbench that goes beyond the inbuilt feature service reader capability which I don't mind given out, but it is setup under 2016 now (and avoids the GET Request).
