I simply want to import a drawing from a client which has the DGN extension; into AUTOCAD 2017. It says " DGN must be in version 7 or 8" and closes the dialog with an error. This FME software is far too complex for such a mundane purpose. I can redraw the entire project in less time than it would take to learn software such as this. Does anyone know of a simple tool to convert non supported DGN files to AutoCad 2017?
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
