We have an SDE that has COM Extension and after copying the data of that SDE to another SDE, the OBJECTID is totally different from the original one. We are using ArcGIS 10.2.1 and FME Desktop 2016.1.
FME Desktop 2016.1 Copying SDE to another SDE did not copy the ObjectID properly
Best answer by stalknecht
That's correct the ObjectID is maintained by the SDE GeoDatabase. So it works as desired.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
