gdalinfo - stats versus RasterPropertyExtractor
  • February 19, 2020
  • 4 views
oliver.morris
Forum|alt.badge.img+12
Hi, is there a more comprehensive way to get a summary of rasper properties akin to gdalinfo - stats from FME - I looked at RasterPropertyExtractor but it doesnt appear to cover things like compression, no data value etc
Many thanks for your help in advance,
Oliver
jdh
Forum|alt.badge.img+28
  • February 19, 2020
The NoData value is band specific, so you would get it from the RasterBandPropertiesExtractor. Things like compression are format specific, so check the format attributes on your reader, the geotiff reader for instance has an attribute geotiff_compression_method you can expose.
