GoogleGeminiConnector
fmelizard
Forum|alt.badge.img+17
FME Hub user chrisatsafe just uploaded a new transformer to the FME Hub.
Google Gemini Service Connector
Overview
The Google Gemini Service Connector is a Custom Transformer for FME that facilitates interaction with Google's Vertex AI Gemini Model via REST API. This transformer allows users to leverage the advanced capabilities of Gemini, Google's large language model, to generate text-based outputs by providing specific prompts and configuring various parameters. This enables a broad range of applications, from content generation to data enrichment across different industries.
For more information, please see the Gemini API documentation.
Note: by default, this transformer is configured to use the Auto Updated Gemini model.
Would you like to know more? Click here to find out more details!
