How can I perform a two dimensional lookup from an external excel sheet?
osasfrer
For example:
I have an external table that has regions for column headings (North, South, East, West) and part numbers for row headings (Part#001, Part#002, Part#003, Part #004,...). A part number in a specific region has a cost as shown in the in the image.
Also, I have another table with the attributes Region and Part Number in FME.
I want to make a new attribute that searches the external table based on the two attributes in my FME table: region and part number and returns the cost. How can I do this?
Annotation 2023-12-18 152500
Best answer by geomancer
This can be done with just a FeatureJoiner and an AttributeDereferencer.
Lookup_Table
joepk
Forum|alt.badge.img+20
  • December 19, 2023
If you make sure your regions are seen as attributes (by e.g. setting row 2 as header in your Reader settings). You can use a Tester for the part numbers and maybe an AttributeKeeper for the regions? The Tester will return one feature/record and the AttributeKeeper will remove all regions you are not interested in.
Hope this helps
geomancer
Forum|alt.badge.img+47
  • December 19, 2023
Lookup_Table
osasfrer
  • December 21, 2023
Lookup_Table
Thanks, it worked
osasfrer
  • December 21, 2023
joepk wrote:
Hope this helps
I want all the records to be displayed all at once in a table
