Reprojector
n.d
Forum|alt.badge.img+7
Hi. I aim to reproject the coordinate system EPSG:25832 to a metric coordinate system. Which destination system do you recommend?
  • July 7, 2023
Depends on your use case, but if you simply want to use it for measuring relative distances or areas in meters, you can try using _AZMEA_NEIGHBORHOOD_
n.d
  • July 7, 2023
Thank you
n.d
  • July 27, 2023
Hello. I have drawed some geometries, and want to set back the coordination system. When I do that, the exported Geometries (in an IFC file) are not looking correctly, for example the circles are like some irregular polygons. What would you recommend to solve that?
Forum|alt.badge.img+49
What coordinate system was used to create the circles and what coordinate system are you viewing them in? Shape distortion is a common side-effect of changing coordinate systems / map projections and, depending on the projections used, unavoidable.
n.d
  • July 27, 2023
The circles are created in _AZMEA_NEIGHBORHOOD_ (as of david_r's recommendation above) coordinate system. And I reprojected them into EPSG:25832.
Okay, the AZMEA indicates it's Equal Area, so no distortion of area but yes distortion of shapes. If you transform it to another system then that's what you're going to get.
Create your circles in EPSG:25832, it's a transversal Mercator projection so, no distortion of shapes.
n.d
  • July 27, 2023
Actually, I had some points (in a CityGML file) in the EPSG:25832 coordinate system at first. The radiuses for creating the circles were in meters. So that I reprojected the coordinate system to the AZEMA. After creating the circles in that system, I want to set back the coordination system to the original one and export them into an IFC file.
The exported IFC file is showing distortion in the drawings. How I should manage it?
EPSG:25832 is already in meters as far as I can tell: https://epsg.io/25832
So no need to do reprojection at all.
