I have a CAD file that has bearings of a line on one layer, distances on another and then the lines themselves on another. I have created a workbench that brings in all three layers, plus others, and then writes the lines out with attributes of the bearing and distance. I am using the NeighborFinder to get the bearing and distance closest to the line but when I write them to the output I am getting double the features that I was hoping for. As shown in the second image I am getting a line feature for each bearing and a separate one for each distance. Is there a way to just get a single line feature with both attributes on it?
