User parameter : difference beetween "Text (multiline)" and "Text (multiline) or Number" ?
mathieu_ambrosy
Forum|alt.badge.img+4
I don't get the difference beetween these 2 user parameters (FME 2017.1) :
  • Text (multiline)
  • Text (multiline) or Number
"Text (multiline) or Number" don't have a configuration button to specify numbers limits (like the Number parameter), so what's the point ?
Regards,
Mathieu.
Forum|alt.badge.img+19
  • September 8, 2017
Hi @mathieu_ambrosy, can you find the difference?
See also "Add/Edit Parameter Dialog Fields > Type" section in this page:
FME Workbench > Working with User Parameters | Creating and Modifying User Parameters
mathieu_ambrosy
Oh !
Thanks Takashi.
It was hard to see !!
