How do I encrypt passwords in FME Server configuration files? Specifically, I want to encrypt the PFX file password used to setup HTTPS for FME Server. I've seen that there's a parameter in fmeServerConfig.txt for ENABLE_PUBLISHED_PARAMETER_ENCRYPTION. How would I generate encrypted passwords to store in the config file, and would setting this parameter to TRUE then decrypt them and let FME server run properly?
