Hi all
I have a simple IFC file which has just 8 IFCWalls and 2 IFCSpaces. When I run a simple query for retrieving all records for IFCSpace elements ( select * from "public"."IfcSpace"; ) , SQLExecutor duplicates all records. For instance, I have 2 records for IFCSpace but after running the query, I'll get 4 records. How can I avoid duplication? (I use PostGIS)
