I am writing to FME 2016 and this worked in previous versions but not in 2016 so finding it quite frustrating that this does not work. I keep getting an error Column 'Type' of type 'char(10)' specified in mapping file but not defined in existing table. The type is based on conditional values. I've checked values in data inspector but it keeps falling every time I go to write my data.
