(General) LiDAR Vegetation Class Question
Can anyone answer a LiDAR point class classification question?
According to the ASPRS standard for point class classification, the following class relate to vegetation:
3 – Low Vegetation
4 – Medium Vegetation
5 – High Vegetation
Can anyone tell me whether there are actual ‘standardised’ (above ground) height ranges associated/relating to each of the vegetation class? If so what at the numeric values?
For example;
3 – Low Vegetation – 0.0m to 0.5m
4 – Medium Vegetation – 0.5m to 1.0m
5 – High Vegetation – 1.0m to >>m
If there are NOT any standard numeric height ranges; can anyone explain what the Low, Medium and High descriptions actually mean in reality? I have looked at various ASPRS documents but can not find any form of detailed explanation.
Thanks
Rob
itay
Forum|alt.badge.img+16
  • November 10, 2016
HI @rob14 I think you can have a better chance on a response in a LIDAR specific forum, unless an FME user can actually answer this for you, good luck!
  • November 10, 2016
Hi itay,
Thanks I will also try this approach.
I primarily posted on the FME forum as users have detailed knowledge in an extremely diverse data sets and backgrounds. :-)
Thanks again,
Rob
