Is it possible to take a binary string in memory and use it in a transformer to tell it to treat it as a zip file? I know I can use a FeatureWriter (format set to data file) to write the binary string to disk then use a FeatureReader to read it back into memory. I was trying to skip the step of writing it to disk. Any help would be great!
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
