HTTPCaller returning 'Couldn't resolve host name' error
Hello,
I've attempted to connect to a few different APIs via an HTTPCaller using GET, in order to lookup UK postcodes based on a list of X & Y coordinates from a CSV file. The URLs being run through the workspace are all valid (I've clicked on them via the translation log, and they appear in internet explorer), but regardless of which API I try to connect to, I always get a 'Couldn't resolve host name' error returned. The APIs I'm connecting to require no authentication, so I that's not the issue. Is it possible the issue relate to restrictions with my corporate network?
Best answer by andreaatsafe
Hi @cjones28,
Have you tried configuring FME Desktop to use the system proxy settings?
You may want to check out these links for more information:
andreaatsafe
Forum|alt.badge.img+10
  • June 19, 2019
Hi @cjones28,
  • June 21, 2019
andreaatsafe wrote:
Hi @cjones28,
That did it, many thanks!
