What what is the precise format for these entries ?
Do the file paths need to enclosed in quotes ? Either seperately or all-in-one ?
What separartor character needs to go between each path ?
Cheers
Lars I.
Cheers
Lars I.
Best answer by lin_geopartner
There seems to be a bug in version 2013 that "decodes" all other occurances of "\\\\" than the first one.
The work-around is to split the UNC part from the (relative) path parts, and instead of just a comma separated list of paths (i.e. "path1,path2,path3"), create an expression as follows:
"UNC_part{rel_path1,rel_path2,rel_path3}"
Of course this only works if all paths have the exact same UNC part. Which they fortunately have in my case :-)
Cheers
