SFTP Caller - Shows single character in attribute called untill i manually sort the column.
This is how the initial output from my ftpcaller looks like ( calling a csv to attribute)imageand this is how it looks like when i sort it by file contents.
imageAny transformer that i use after calling the data uses the first screenshot, thereby inhibiting me from automating any process.
I have to download to file, open and save it and then re add it to a second script to manipulate it and push it to AGOL ( which is my end goal)
Be the first to reply!
