In the Feature Inspector, you can see the Geometry and the Contents. The Contents section includes the Property and Data Type columns. Where is Values column? How do get I the Property values to display?
  • November 23, 2023
The newer version solved this issue!
j.botterill
Forum|alt.badge.img+36
  • November 24, 2023
"Feature Information" window is your go to for inspecting values for selected features
