Use list of files in Excel to copy into a ZIP file
  • May 17, 2021
  • 100 views
tim_wood
Forum|alt.badge.img+8
We have a set of DWG files covering our geographical area. Sometimes we need to supply contractors with a subset of these files. The files are named by their map reference. We can generated a list of the required files using our GIS.
So we have an Excel file with a list of these tiles in, which are also the file names of the DWGs. I have built a Workspace in FME 2020.1 to read the Excel file, construct the path and filename, and pass it to the FileCopy Writer. This successfully copies the files to a folder, but when I try to get it to ZIP the files, I only get some of them, and this message appears in the log: 2021-05-17 17:22:04| 13.4| 11.2|WARN |MULTI_WRITER: Skipped adding of some files to zip file 'X:\\SomeFolder\\selected_DWG_files.zip' because they already exist
I don't understand the error because all the DWG file names are unique. I assume it's referring to the ZIP file, but I don't understand why I get varying numbers of DWG files in the ZIP each time and why some are being skipped.
I have tried suggestions from other topics e.g. not specifying filecopy_dest_dataset and using the FeatureWriter transformer instead of the Writer. But none of these work.
I have tried building a Workspace that checks for the existence of the ZIP file and moves it out of the target folder if it's already there - so that the FileCopy Writer is creating a fresh ZIP each time. But that doesn't work.
This felt like something that should be a 5 minute job but I have been going for nearly a day on it!
Best answer by tim_wood
As usual, as soon as I ask the question, I figure out the answer!
I think it's because I was generating the output as follows:
@ReplaceString(@Value(fme_dataset),@Value(fme_basename).xlsx,"")\\selected_DWG_files.zip
I discovered the \\ was including was unnecessary - there was already one there in fme_dataset. So I was adding a duplicate \\ which I believe was causing the problems. D'oh!
tim_wood
  • May 18, 2021
