Get attribute names with Python to a column in Excel
I am trying to get attribute names from multiple input MapInfo files into one column in Excel with PythonCaller.
I can get it to print in the Log but it doesn't go out to the Excel reader. Not too sure what the problem is - I use the script below:
import fmeobjects
def processFeature(feature):
pass
class FeatureProcessor(object):
def __init__(self):
pass
def input(self,feature):
feature.removeAttrsWithPrefix('mapinfo_') feature.removeAttrsWithPrefix('fme_') feature.removeAttrsWithPrefix('multi_')
attrNames = feature.getAllAttributeNames()
inputAttrNames = []
for attrname in attrNames: inputAttrNames.append(attrname)
feature.setAttribute('_inputAttrNames', inputAttrNames) self.pyoutput(feature)
def close(self): pass
I have also tried in the for loop -
feature.setAttribute('_inputAttrNames', attrname)
Thanks!!
Forum|alt.badge.img+7
Hi judychang,
Just a small question. Did you expose the newly created attribute in the PythonCaller?
  • May 17, 2016
Hi
Rather than struggling with Python, have you looked at the AttributeExploder? The contents of the "_attr_name" attribute should be what you're looking for.
You can then use a Tester to skip those starting with "fme_" etc.
David
  • May 17, 2016
jeroenstiers wrote:
Hi judychang,
Hi @jeroenstiers, yes I did. I think it's to do with data structure - when I tested for a constant feature.setAttribute('_inputAttrNames', 'test') it worked.
  • May 17, 2016
david_r wrote:
Hi
David
Hi @david_r,
Thank you! That's what I was looking for.
