When you use the SDERASTER reader or the SDERASTERCATALOG writer or the SDERASTERMAP writer it allows you to initially use the OS Authentication option but when it gets added to the canvas the username and password fields are empty and red. It won't let you run the workbench until they are filled in. How do you get it to use the OS Authentication option correctly?
Thanks,
Peter.
