I would like to know if it is possible to set a feature type to read only a small sample of its data to test a workspace instead of waiting that all the data of this feature type is loaded.
Thank you!
Thank you!
Best answer by fmelizard
Yes you can define that with the max features to read parameters at the navigator > reader> parameters> advanced
Itay
