Open
Azure Database with Active Directory Universal and MFA
Related products:Integrations
siennaatsafe
erik_jan
j.botterill
dave29
ashish_man
+10
  • siennaatsafe
    siennaatsafe
  • erik_jan
    erik_jan
  • j.botterill
    j.botterill
  • dave29
    dave29
  • ashish_man
    ashish_man
  • smas1
  • garrettcronin
    garrettcronin
  • cblack
  • jnorling
  • braggken
    braggken
  • mpab
  • jbulman
    jbulman
  • stukay
    stukay
  • chris
  • vuj001
    vuj001
Idea: Develop a reader to connect to Microsoft Azure using the Azure Active Directory (Universal) with MFA support.
Background: Currently there is an increasing need to connect to applications using Microsoft Azure Active Directory with MFA. It is easy to connect to a Microsoft azure db using SQL Server Management Studio - the more recent versions allow this connection. The idea is that FME use the same connection method to allow connections to azure databases. I have seen some work arounds using JDBC and ODBC, however I believe this to be worthy of its own idea.
Be the first to reply!
