Read multiple file and save on multiple file.
  • August 4, 2014
  • 2 views
Hello, I have points on many file on a side.
On the other side i have a directory with multiple cad file each cad have 1 boundarie
I make a workspace with a buffer/clipper and a reader to read all points.
I don't want to insert each boudary and insert writers with the same name.
I want to scan the directory for cad file, For each file this write a csv file with the point.
All of this work perfectly for 1 file but is a way to make it for each file ?
Best answer by gio
You can do this using dynamic readers and writers, possibly  in combination with a workspacerunner.
Htere are lot of samples for this dynamic contruction on this forum.
gio
Forum|alt.badge.img+15
  • August 4, 2014
