Oracle DB connection
I have created a FME workbench v2017 (on my development machine where i got oracle client installed) in which i am reading and writing data into oracle database tables.
Now I need to publish this workbench as a 'jobsubmitter' service into FME server and schedule it to run.This FME server doesn't have oracle client installed.Just wondering is there a way i can connect to the database without oracle client?
I mean can i use JDBC to connect oracle database? If so how could i achive this?
Any response would be helpful.
Thanks,
reachmj
  • June 30, 2017
I had a customer using JDBC to read from Oracle and there was a performance hit compared to the native client. Wondering if spatial data is supported through JDBC because I seem to remember it wasn't at some point.
Some info here :
https://knowledge.safe.com/articles/701/using-the-generic-database-jdbc-format.html
  • July 6, 2017
Some info here :
@reachmj did you managed to try this?
  • July 10, 2017
Hi Mark,
Thanks for your response and apologies for my delayed response as well.The config file changes for the jdbc db connection is to connect to the FME Repository database and i don't know how to connect external DB which we use in our Workbench translation using jdbc without oracle client.So i went with oracle client installation and connecting the DB through tns.
Thanks,
reachmj
