I have 2 layers with points features in shp.
I want to create a tool that finds the nearest point from another layer of points only if the layer as the matching attributes and then snap to the nearest point, regardless of the distance, only the one that is closer to it and has the matching attributes.
Example: 2 points with a oak attribute as sort.
Thanks ahead!
Isabelle
