group by
  • February 26, 2020
  • 19 views
HEllo,
I want to create an attribute (distance) between two points. I am using AttributeCreator to do it. Here is the code:
@Evaluate(@sqrt((@Value(feature[+1].y)-@Value(y))*(@Value(feature[+1].y)-@Value(y))/(@Value(feature[+1].x)-@Value(x))*(@Value(feature[+1].x)-@Value(x))))
The problem is that I want to calculate it only between points where lineID is the same. How can I add a kind of group by?
Thanks
Forum|alt.badge.img+32
  • February 26, 2020
You can use a conditional statement in the attributecreator, if @Value(LineID) = @Value(feature[+1].LineID) use the above expression, if not do nothing
  • February 26, 2020
@gylona or perhaps try the NeighborFinder?
