Clipper stuck without error (data+workspace included)
takanaka
Forum|alt.badge.img+4
Hi, I'm running into an issue that I don't understand the solution to.
Using the geometries attached here, I can not clip the geometries using a tolerance of 0.001 .
It does not give an error, it just gets stuck.
If I dissolve the clippers before clipping, it does work.
So I'm guessing there's something 'wrong' with the geometries (there is a strange pointy shape in the polygon) and the chosen tolerance, but I don't know why it gets stuck. I'm guessing the pointy-bit is too small and falls under the tolerance?
I'm using fme 2022.1.2. Workspace attached and data attached.
danminneyatsaf
Forum|alt.badge.img+12
Hi @takanaka​, I can't say for sure why the clipper is failing to start and finish running when processing spike geometries with a lower tolerance. I've created a ticket for us to look into this and potentially resolve the issue in a future version of FME. If a fix is released, we will notify you here. For your reference, the ticket number is FMEENGINE-77448.
Thanks for your understanding!
Dan M
danminneyatsaf
Hi @takanaka​, the issue has been resolved and the fixes are now available in the FME 2023.1 beta and will be available in the full release once that is made available.
Please let us know if you're still having issues with the Clipper after installing FME 2023.1.
