Hi guys,
I am trying to automate a process which requires to write into a new file-geodatabase everytime i run. is there a way that FME can create a new file geodatabase for my feature classes in a same workbench?
Thanks!
Hi guys,
Thanks!
Best answer by mygis
Hi @sangli
If you mean to write in the middle of a process you can use the FeatureWriter transformer . You can place it anywhere in the transformation process and continue with the translation.
Which version of FME are you using by the way?
Cheers.
Lyes
