I'm trying to find the line that begins with "API" and insert a file number (from the file name itself) after that API reference. The goal is to overwrite any data/text that appears after the API with only the file number. I've got and extractor and a stringreplacer in place, but wanted to know if there are "wildcards" that can be used in FME to help accomplish the replace. TIA
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
