Running a workspace with prompt using a batch file
Hello everybody,
i know it is possible to run a FME workspace by using a a batch file. But what is the command in the batch to run this workspace with prompt?
With kindest regards,
Felix
Best answer by redgeographics
You could run "fmequicktranslator.exe myworkspace.fmw", that will pop up the Quick Translator with that workspace so your user will get the parameters dialog.
Forum|alt.badge.img+47
  • June 26, 2017
  • June 26, 2017
Hi @felixderglueckl
What is suggested above, or run the Workspace in FME Desktop then look at the top of the log file for the command. You don't get the prompt however!
mark_f wrote:
Hi @felixderglueckl
But that wouldn't prompt, right, just take the parameters as they are specified?
  • June 26, 2017
Yep - why I said you won't get the prompt which I know the OP requested but just pitching it out there as a possibility.
mygis
Forum|alt.badge.img+12
  • June 26, 2017
I don't think it is possible to have the prompts popping up when a airspace is run from a batch file. However you could add variables from the dos prompt in the batch file if not mistaken .
