CityGML 3D Reprojection failed
  • October 11, 2017
  • 30 views
Hello everyone,
I have a CityGML dataset from Montreal Open data that seems to be in EPSG:2950
I need to write this CityGML to a Cesium 3D-Tiles dataset (tileset.json + tiles) in EPSG:4978
I tried Reprojector and CS-MAP Reprojector but in vain.
I get an error when I try to do so :
daveatsafe
Forum|alt.badge.img+19
  • October 11, 2017
Hi @clement,
The Cesium writer will automatically reproject the output data to the EPSG:4978 coordinate system, as long as the data sent to it has a valid coordinate system. Please try removing the CsmapReprojector transformer.
If you do wish to reproject to a Geocentric coordinate system like EPSG:4978, you must pick a Vertical mode as well, since the elevation is reprojected as well. The best setting for most source coordinate systems would be 'Heights are relative to the ellipsoid(s) or geocentric'.
