Building Heights from OSM map
  • February 25, 2019
  • 26 views
Hi, we use Infraworks at work to bring OSM/OSNI to create quick contextual design for our sites. As of now, the heights of buildings are adjusted manually and it takes really long time applying height to each building. I was wondering is there anyway FME can extract this out?
Forum|alt.badge.img+47
If you have an attribute with the building height you can use an Extruder to create basic blocks.
