Uploading a file geodatabase to FME Server from the web interface
A user is supposed to use FME Server's web interface for running a FME workspace that has been published on it. That FME workspace takes a file geodatabase as input. The user should upload his/her file geodatabase at runtime in the web interface for that workspace. The problem is that the browser will not let the user select the folder defining the file geodatabase. Furthermore selecting all subfiles of that geodatabase will lead to a failed run. What is it that I am overlooking? Thanks in advance!
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
