Clip ESRI multipatch files with FME
  • February 9, 2013
  • 29 views
ceciliac
Is it possible to clip ESRI multpatch files with FME?
Wich FME transformer should I use?
Thanks!
davideagle
Forum|alt.badge.img+21
  • February 10, 2013
Hi there. It perhaps seems a bit obvious to say it but have you tried the 'Clipper' as it does cope witb 3D. There are some examples here, though not directly related to multipatch geometry: http://fmepedia.safe.com/articles/Samples_and_Demos/Point-Cloud-and-3D-Clipping
ceciliac
Thanks!
