Hi, when securing our DB Connections I noticed that the only choice for the Connection security item, either by user or by role, is "Full Access". Does that mean that an (FME or Active Directory) user that can use the Database Connection also has the right to delete it? Or does it mean that the user always can use the Database Connection yet only can remove it if the user has Full Access?
