Using FME to Populate/Explode Missing Date Records With Values From Last Updated Record
scobierob
I am trying figure out how to populate missing date records in a COVID database using the last known value.
Here is an example of input data:
CountryLast UpdateNumber of CasesMexico3/1/20205Mexico3/3/20205Mexico3/6/20206Mexico3/8/20207Mexico3/9/20207
I would like to generate a record for each day.
CountryLast UpdateNumber of CasesMexico3/1/20205Mexico3/2/20205Mexico3/3/20205Mexico3/4/20205Mexico3/5/20205Mexico3/6/20206Mexico3/7/20206Mexico3/8/20207Mexico3/9/20207
Any ideas on where I would start with this one?
fmelizard
Forum|alt.badge.img+17
  • April 1, 2020
Hi @scobierob You'll need an AttributeManager to get the date of the next record. Use a DateTimeCalculator to find the difference, clone by that, then recalculate the dates with a second DateTimeCalculator.
scobierob
  • April 1, 2020
Hi @danatsafe,
This brilliant. I've been testing it on my data but I noticed an error in the output of the workbench you provided.
The result of the workbench you provided is close but it is off by a little:
Mexico 02/29/2020 5
Mexico 03/01/2020 5
Mexico 03/01/2020 5
Mexico 03/02/2020 5
Mexico 03/03/2020 5
Mexico 03/05/2020 6
Mexico 03/06/2020 6
Mexico 03/08/2020 7
Mexico 03/09/2020 7
It seems that some dates are missing and some dates have been duplicated. Could this have something to do with a timezone setting?
scobierob
  • April 1, 2020
I would also like to avoid having dates for days that are precede the first date entry (ex: Mexico 02/29/2020 5 )
Cheers!
fmelizard
  • April 1, 2020
Cheers!
Hi @scobierob Sorry about that! In DateTimeCalculator_2 the Operator should be 'Add', not 'Subtract' Missing_days2.fmwt
