Is it possible to enforce the minimum password length for FME server from application?
If yes, what is password policy and how to enforce?
Best answer by david_r
As far as I know, this isn't possible using the built-in FME Server authentication.
If you use an external authentication system, e.g. Active Directory, you should look into implementing the policies there.
