Archived
TestFilter Fanoutput ports tool
Related products:FME Form
  • October 18, 2023
  • 57 views
reedwhit
I find my self doing this manual process a bunch where I like to have output ports on the TestFilter named by cached values of a particular attribute and a simple test condition on that attribute. This helps visually understand and present workflows. for example if we are doing feature routing based on an attribute value. It would be very nice to have a tool in the TestFilter that auto populates output port based on an attribute value and at the same time add a test condition for that attribute to each main row of the TestFilter. This kind of relates to another idea to have the TestFilter save the value of an output port to an new attribute.
LizAtSafe
Forum|alt.badge.img+15
  • February 12, 2024
Updated idea statusGathering InterestArchived
Idea merged into:
All the votes from this idea have been transferred.
