Expose domain values to a new feature class
  • November 28, 2016
  • 23 views
Hi! I have a feature class with a coded domain on a short integer field, which refers to cities' names. I want to export it in a new feature class, but expose the associated coded-values description in a string field, and no more use of the coded domain; i.e. instead of value 1 for the city oh Washington, to store only "Washington"
thanks!
Best answer by itay
Hi @roxananazarie have a look at the resolve options in the reader settings.
This way values become available for mapping.
Hope this helps.
itay
Forum|alt.badge.img+16
  • November 28, 2016
Hope this helps.
Hi! yeah, thanks it works by checking "Resolve Domains" on the Reader. Now I have another problem, the coded-values description originally contain diacritics like "?", "?", "?". The values in the resulted <attribute-name>_resolved replace these characters with "?"
