Exiting table feed no records and out is null
Forum|alt.badge.img+5
I trying to insert the record on the Exiting table but it's giving me null values with successfully
image" data-fileid="0694Q00000LGK5uQAHimage
carmijo
Forum|alt.badge.img+11
  • October 3, 2022
Hi @asadamjad, what writer type are you using? i would start by checking the writers user attributes tab and use the automatic setting if possible for your use case
image--
If i've provided something helpful, please upvote the comment. If i've provided a solution, please mark it as 'Best Answer'. This helps the community find solutions when your question is referenced.
If I didn't provide a solution, please let me know if I can help further. Thanks! 🙂
  • October 3, 2022
This is the Workspace ....
carmijo
  • October 3, 2022
I think more information about the problem would help. I was expecting to see a writer but I'm not seeing any in the workspace
  • October 4, 2022
please check workspce
